Yeah, they work pretty well. Putting one on an analyzer shows very broad band (<2:1SWR) from 144 up to 170MHz. 3/4 wave on UHF, as you stated.
I ran one with a dual band amateur radio for years, and never had an issue with performance.
I've tried recommending them to people, but I think most are swayed by good (bad?) advertising. Seems like the more coils, elements, do-dads and antenna has, the "more better" people think they are. Inflate the cost a bit and it seems like some believe the manufacturer has some secret sauce that makes them cheat the laws of physics.
If I was a nefarious type, I think I'd probably go into the magic antenna business. Seems like I could make a fortune off hobbyists. Add a bunch of loading coils, curly-q's, couple of whips sticking off at odd angles, and of course, magnet mount for those that can't get the wife's approval to drill a hole in the mini-van. Jack of the price and use some dubious gain numbers for good measure.
I do suspect the cellular interference you are experiencing is because of the antenna gain on 800. The 1/4 wave VHF would have less gain and less interference. Scanners are not the most selective receivers, too. With a commercial 800MHz radio with a good front end, it's not usually an issue.
