SDS 100 Volume
philkoz
Anchor Bay, SE Michigan
Minor issue, especially compared to how great the specs are looking, but anyone know if the audio output will be better on the SDS 100 ? I have a 436x now and the only complaint I've ever had except for the same simulcast issues as everyone else, is the low audio output. Very low in the car & carrying outside. Found a 12v amplified speaker for the car, but haven't had any luck locating a shoulder-type speaker that works well. Hoping the SDS 100 is better.
Thanks...
ShyFlyer
Colorado
I think we'll see (or rather hear) the same output from the jack on the SDS that we experience with the 436.
KB7MIB
Peoria, AZ.
A better speaker would be great, but I think the scanner manufacturers deliberately limit the audio output into an external speaker or earphone, so as to protect our hearing. My GRE PSR500 has the same issue when I've tried to use an earphone to listen at a loud outdoor event. It just isn't loud enough over the crowd, musicians, and everything else.
John
Peoria, AZ
Phillipsc84
Fort Mill, SC
The output is fine to me.
With my 436 in a loud car or outside the volume feels pretty low. Any feedback on how well the SDS100 does in those conditions? I'd have to max out the volume on the 436 to hear it in my work van and that kind of distorts the audio at times.
jonwienke
More Info Coming Soon!
VA
The SDS100 is a bit louder than the 436, and can get louder without distorting.
In a noisy vehicle you will probably want to run an amplified speaker.
eaf1956
Evansville, IN
My SDS 100 is loud on one P25 system but low on another. What systems you say:
Vanderburgh P25 Simulcast is LOUD
In Safe T P25 seems low
If you turn the scanner up to hear one the other is too loud. Kinda wish there was a SYSTEM volume offset so as not to have to change every talkgroup on a system.
N0GTG
Scanner programmer since 1997
Denver, Colorado
Another option in a vehicle: many have AUX (auxiliary) inputs, which means your scanner audio is amplified by the vehicle's sound system and sent to those speakers. All the audio you could ask for, and all you need is a 3.5mm (1/8") audio cable for a few bucks!
