Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Uniden Forums > The Uniden Tavern
The Uniden Tavern - For general chit-chat and non-technical discussion specific to Uniden and does not fall within the above forum topics. This is not the forum to get technical advice from.
Old 06-06-2018, 12:42 PM
Default SDS100 your likes / dislikes
I like the ease of use and key pad
Oh,
And l almost forgot,
I like that i can scan while charging!
Thanks paul
Old 06-06-2018, 12:43 PM
UPMan's Avatar
Uniden Representative
Um...you can scan while charging. So maybe edit your post to "I like that I can scan while charging."
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Originally Posted by vocoder View Post
I do not like that i can not scan while charging
I thought this was possible? I've got mine plugged in right now and it's scanning, though I have no idea if it's charging or just bypassing the battery and powering the unit.
Old 06-06-2018, 12:47 PM
It charges when i have the power off
So it is supposed to be different from my other unidens? 325p2 436hp
Looking over manual again
Old 06-06-2018, 12:49 PM
I like the display, alot!
And all the detailed info the scanner and display offer!
I like the way it handles p1 and p2 tdma simulcast!
Old 06-06-2018, 12:51 PM
dconti's Avatar
Great.... but how does it WORK??????
Old 06-06-2018, 12:55 PM
UPMan's Avatar
Manual is incorrect (had to be completed 2 months ago, before we actually had updated units that would charge while on and there was still some question). At some point, this and many other things will be revised.
Personal Blog
Old 06-06-2018, 12:57 PM
I think i am missing something, then
I just unboxed it, though
Programmed
Started scanning
Playtime needed
Old 06-06-2018, 12:59 PM
UPMan's Avatar
First Bullet (now): SDS100 Wiki Page
Personal Blog
Old 06-06-2018, 1:22 PM
https://docs.google.com/spreadsheets...S3M/edit#gid=0
Old 06-06-2018, 1:45 PM
I've had it for a day and it's great. These are just some quick pros from a usability/ergonomics standpoint.
* Display is much easier to read than the standard LCD displays we're used to. Definitely one of the selling points for me and has exceeded expectations. Night and day having it on next to my x36 models and the distance from which I can read the SDS100 display compared to the others.
* Selector knob is a beefier version of the one on the 436 thank god because the one on the 536 never worked right and was hoping they'd stick with a crisper clicking knob to select systems and menu items.
* Form factor is nice. It's light and small and fits your hand nicely and doesn't feel unstable standing up on a table. The bigger battery door should make it even more stable when standing it up.
* Speaker is fine. I know some were concerned about it being sacrificed for water resistance, but it gets plenty loud for my ears. I am listening to it in general on a volume of about 8 which is 50% max volume.
* Back lit keypad is a great idea and the keys are easy to press and spaced far enough apart to avoid pressing an adjacent key. I wasn't sure this one piece key pad would be as good as having discrete keys, but so far so good, and worth any trade offs for the back lighting.
* I like the soft keys. As I said in one of the other threads, the only thing I wish you could do is customize their function and label. I'd like to basically be able to label one FIRE or EMS for example and when pressed have the scanner switch to a scan list tailored for scanning systems and channels for those types of incidents.
Can't wait for the base/mobile version of this.
Old 06-06-2018, 1:53 PM
Yep, i would like to have the soft keys user programmable, too. I was a little siked up at first, thinking they were. Not a big deal, maybe down the road
Old 06-06-2018, 2:29 PM
03msc's Avatar
Awesome report. And maybe a future firmware version will allow for editing/customizing the softkeys? It seems that might be easily implemented but I'm not positive.
Mark Arkansas
Uniden Whistler Kenwood Yaesu
Old 06-06-2018, 3:49 PM
wise871's Avatar
So far I concur what has been said. One thing I noticed is how small and light it is compared to my other handhelds.
Dan
Uniden:SDS100,BCD536HP,BCD996p2,HP-1/2e,BCD396XT,BCD996T(XT),BCT15X, BC898T
Radio Shack:PRO-197,PRO-106
Vintage:PRO-25,Sony Air-8
Old 06-06-2018, 3:50 PM
03msc's Avatar
Side by side pictures??
Mark Arkansas
Old 06-06-2018, 3:55 PM
dconti's Avatar
All this cosmetic hyperbole is fine. Buttons, knobs, weight, yada, yada, yada.
Again... HOW DOES IT WORK AS A RADIO? Reception, operational functioning, etc.
That's what is important to me...
Thank you
Old 06-06-2018, 4:02 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Thank you
Do you have difficulty navigating the forums here at RR?
You should be able to easily find the following thread yada yada yada.....
Why do I get the sneaking suspicion you won't like the overwhelming positive reports located within?
http://forums.radioreference.com/uni...oogle-doc.html
Marshall KE4ZNR
Sent from my Pixel XL using Tapatalk
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
Old 06-06-2018, 5:00 PM
buddrousa's Avatar
Having to wait one more night before I get to play.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
Old 06-06-2018, 5:03 PM
Viper43's Avatar
Thank you
Well, all that yada, yada, yada is also what MAKES it work as well as it does, so, yup, there is that too.
HP-1 x 2, BCD396XT, BCD396T, BCD996T, PSR600, Pro2035, Pro2035+535, Pro2052, Pro94, Pro97,Pro-2096, R71-A, PCR-100 x 2, PCR1500 and 12 other scanners/recievers.
Old 06-06-2018, 5:10 PM
Viper43's Avatar
1: I can actually hear all 4 IDPS (Indianapolis) systems at home. Something no other scanners can do!
2: the display, from info displayed to the colors available
3: I like the feel of the case, it fits the hand nicely and the texture is good too.
4: rain resistance, a huge plus compared to others.
5: charge while scanning, love that!
6: keyboard
The ONE thing I think I'd change is on the port cover I'd have that reversed where it opens upward not downward. If you don't get it back in completely i could see water getting in it as it wears. Otherwise, wow! Great radio!
