Yes it has.Does the SDS200 have the DMR upgrade key added?
There seem to be a firmware difference between x36 and SDS that makes simplex handling in SDS flawed.
/Ubbe
Dumb question: what is DCDM?
I tried DCDM as both a conventional and a DMR OFT in my SDS 100, and it wouldn't decode it either way. I haven't tried it in Mototrbo trunk mode, but will try that over the weekend.
I also have troubles with DMR OFT decoding a system that it will receive in conventional mode as well.
Then, AEP set their P25P2 network up in TDMA CC mode, and turned off the EDACS system, so that doesn't work either.
Needless to say, I'm disappointed in a 700 dollar radio that hasn't had any bug fixes or feature releases to remain current, and will take my money to BTT and other companies that stay on the front line.
I understand the last 2 comments has nothing to do with the original post / complaint, but I'm tired of Uniden ghosting us for the past year.
(Edited for clarification.)
Yes sir I did. I bought the radio in Spring of 2019, and at the time, Uniden was involved in the scanner market, and was rolling out frequent updates. In my world, service sells, so I bought it at that time. I hate that Upman died, but it's been long enough, Joe Bearcat has announced himself, but nothing gets fixed. Fast forward to July 2021, Harris rolls out TDMA CC on the AEP Texas system, and the SDS series is useless at this point. BTT had a fix within a few weeks, as did DSD+. I saw a post on communications support forums where a member was asking for sample data stream files, but to my knowledge, I haven't seen any activity similiar from Uniden.OH, and did you research places like here to see what you were buying, BEFORE you spent $700?
Well...a few things come to mind, but probably a programming error is more likely.
be glad to share the file in a PM or other if you want to look at it. It just doesn't decode it, even though in conventional mode it never misses a transmission, and shows a DMR Slot 1 on the same talkgroup everytime. I think they use Hytera radios in a Psuedo trunking mode, because they also use the DCDM in simplex, and it won't decode that either. For comparison, a Anytone D878UV in Digital monitor will hear the system.
Not a database system, it's an Itinerant contractor on 451.8125 with a portable repeater. Anytone won't receive a Cap+ system, but receives this. I've seen Hytera radios on site. Filters on global, service types on Custom 1. Got it in a favorites list twice, once as conventional, once as a OFT. Location control is on, but same lat / lon / range in both sytems. Holding on the OFT site shows a signal in the corner, and sometimes DMR Slot 1 a the top, but no audio even though AT radio has audio. Swapping to conventional system will pass audio. Conventional always shows DMR Slot 1, TG 100, RID's between 1001-1099. Same on Anytone radio. I've gone through old posts here and a logic table / tree to diagnose, but starting to think it's a SDS100 issue.
