Like the title says, I just realized that my SDS100 startup screen says SDS200. Does this mean anything? I saw someone had a spelling error on their startup screen for the 200, but nothing about this.
You can make the startup screen say anything you want by changing it in Sentinel, doesn't mean anything. Open the profile editor in Sentinel, click on the "Display Options" tab, and change it there under "Opening Message", and then write to the scanner. You can even change the start up screen to display a customized graphic if you want.Like the title says, I just realized that my SDS100 startup screen says SDS200. Does this mean anything? I saw someone had a spelling error on their startup screen for the 200, but nothing about this.
As others have said "Nothing to worry about" - most likely the programmer copied a SDS 200 Profile along the way and forgot to change the screen.
I would be a little more concerned if it said something other than SDS. . . such as BCD436HP. There is a setting called "Target Model" accessed in the Tools menu and the incorrect one may have been selected. Sometimes this can cause a performance issue if not set properly.
Then, mount your radio and place this in the root directory (BCDx36HP) of your SD card.
This will give you a nice SDS100 opening graphic.
Or, as others have said, by editing profile / display options / opening message - it edits the boot text that is displayed
Thank you all. I will use the sentinel software to change the target model to SDS100.
I have been struggling with getting the GPS to work. Could the wrong Target Model be related to this? To be fair, I have been trying to make the Garmin GPS serial puck from my 996 work, so that could be the issue by itself. I understood that several people have made this work, but despite trying everything they had documented i have had not luck.
The most common error with GPS is the baud rate. If you have the older round puck be sure the baud rate in the scanner is set to 4800. If you have the newer square GPS the baud rate is 9600.
-Its not very interesting, but sure. I did change the target model and no change. Seems like its not relevant to anything from what I am understanding.
Did you save your changes and then Write to the scanner?
Are you using the "profile editor" in Sentinel to make changes as outlined in post #2 above?Yes sir. No change.
Changing the target model does not change any of the opening message text. If you want to change it, follow the directions already given in post #2 above.
I did that on my 436 If found, please call xxx xxx xxxxand maybe add your name in case it gets lost...
reward if found, my name, my phone #I did that on my 436 If found, please call xxx xxx xxxx
