SDS100/200 Frequency Rounding
Facsimile
I'm curious as to why I cannot manually enter a frequency without the scanner automatically rounding? If I enter a site frequency on Sentinel, I can set it to whatever I want. For example, if I have a control frequency of 451.89375, which I do, I cannot enter that manually without rounding even if I set the step to the lowest setting. It has to be entered through Sentinel.
Ubbe
Stockholm, Sweden
Uniden doesn't reveal their scanners frequency accuracy but I took a look at a professional Motorola radio at it said +/-2ppm. That's parts per million and MHz are millions of Hertz. At 1MHz it could be +/-2Hz. At 800MHz that's +/-1,5KHz. A valid frequency error in that mobile radio would be 800,00150 or 799,99850
Any scanner are probably worse than that as it's filters are more wide to allow for more drift of its oscillators, as a scanner are usually not sent in for calibration as professional radios often are after a couple of years of use.
My Uniden BCD536 and Whistler TRX-2 are 1KHz off in their frequencies at 500MHz, at different directions. That's a 2ppm error.
But as mentioned the bandplans step size selected and programmed must match the frequency you would want to enter.
/Ubbe
Hiding in a coffee shop.
/Ubbe
Right, and when the radios are tuned, it's usually a goal to be less than 300Hz off channel. It's not hard at all to do a less than 10Hz off frequency on a modern quality radio and a little bit extra time. I've got 12 year old Kenwoods that will come down to a couple of Hz.
And when you figure in simulcast systems, they are using GPS disciplined oscillators for frequency reference. Digital systems usually require fairly close tolerances, also.
KevinC
Big Dog...celebrating 10 years of abuse!
Super Moderator
Home
/Ubbe
All the APX-series are +/- 1.0 ppm or less (some are .9 or .8).
JoeBearcat
Uniden Representative
It's not rounding. The last digit is simply masked (not shown).
