Closed Thread
  #221 (permalink)
Old 07-04-2016, 8:50 AM
buddrousa's Avatar
Originally Posted by BCasto View Post
For some reason(s) some TGs on my BDC996XT have the loud hammer sound (growl if you prefer) and some don't. It can last for a couple seconds. It is such an annoyance it makes monitoring difficult. Is it a matter of adjusting P25 settings or is it something else? Appreciate your help.
You may also look at signal strength or even desense from a very near frequency that is not always present and causing intermittent problems. Look in your area for a frequency near your receive channel lock a second scanner on the near frequency and monitor both for the problem.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
  #222 (permalink)
Old 07-04-2016, 11:29 AM
W6KRU's Avatar
I suggest starting your own thread for your problem instead of hijacking this thread that is about x36 scanners.
73 de W6KRU - Dan
WS-1080 PSR-500 BCD436HP BCD396XT BCD396T FRG-100 PRO-43 PRO-90 PRO-2050 FT-857 FT-90 VX-170 VX-3
  #223 (permalink)
Old 07-04-2016, 1:59 PM
BCasto's Avatar
Default Hijacking
Didn't intend to hijack and thought a discussion about p25 decoding might be appropriate. Sorry.
  #224 (permalink)
Old 07-04-2016, 3:01 PM
darunimal
Guest
Posts: n/a
Your Issues are corollary to other Settings than your P25 settings per 'se PM SENT
DMA P25 Decoding and Audio Issues - The RadioReference Wiki
Digital End Code detection - The RadioReference Wiki
P25 audio decode level adjustment - The RadioReference Wiki
Closed Thread
