  #41 (permalink)
Old 01-21-2015, 1:52 PM
PJH's Avatar
PJH PJH is offline
Global Database Admin
BC9000 was a nice size. It would be nice to be able to just enter a channel or two to listen without the scanner asking a bunch of questions (aka the 536). Sometimes its nice to sit in front of something and enter a few things without having to hook up to a computer and do adjustments.
780+9000 with modern features would be nice.
If you have received a PM from me about a submission, kindly reply within 5 days with requested information or your submission may be rejected. Thanks!
  #42 (permalink)
Old 01-21-2015, 1:57 PM
mule1075's Avatar
I am with you to a point I will take a 9000 with a 996xt display. I would be quite happy with that.
Sent from my Z750C using Tapatalk
Uniden BCD536HPx2/250D Motorola HT1000/GM360
  #43 (permalink)
Old 01-21-2015, 8:42 PM
stingray327's Avatar
Thumbs up
I agree with you 100% on it would be great to have the option of entering information manually rather than depend on a computer.
  #44 (permalink)
Old 01-21-2015, 9:06 PM
I always thought it would be awesome to have an actual home desktop scanner with all the bells and whistles instead of using a mobile scanner as a base scanner.
  #45 (permalink)
Old 01-21-2015, 9:33 PM
As a base station I agree with you.
I am using a 436 as both a base and in car. It is horrible as a base as it is not stable difficult to read screen and it keeps falling down.
In the car when I pick it up it stops scanning because of the side lever/function switch on side is activated by me grabbing scanner. I would think that this is a poor design so I just pick it up differently.
  #46 (permalink)
Old 01-21-2015, 9:38 PM
N8IAA's Avatar
Have you ever thought about a metal bookend bent back a bit? That's what I used until I made a custom stand out of a charging station for cell phones.
Larry
  #47 (permalink)
Old 01-21-2015, 9:39 PM
NWI_Scanner_Guy's Avatar
Try a stand of some kind. That will give the scanner much needed stability and keep it at an angle for better viewing of the screen. They're available on eBay and I think Scanner Master has them as well.
BCT-15X / PRO-2051 / BC-355N
SDS-100 / BC-246T / BC-125AT / PRO-107 / PRO-137
ALINCO DR-605 / UV-5x3 / UV-82HP / UV-82X / UV-3R+ / ANYTONE NSTIG-8R
  #48 (permalink)
Old 01-21-2015, 9:42 PM
mule1075's Avatar
Grab it from the bottom and problem is solved.Below the screen and grab and yes it going to be horrible as a base because it is a handheld.
  #49 (permalink)
Old 01-21-2015, 9:49 PM
That's what I have to do or grab it anywhere else and don't touch the keyboard otherwise something will get activated and cess to scan. I could engage the lock button but then that limits me if I need to make some kind of adjustment or volume adjustment etc.
  #50 (permalink)
Old 01-21-2015, 9:54 PM
The thick cable from the ST-2 antenna t makes it very difficult to position scanner. I actually position the antenna cable to move or stablize 436 handheld scanner.
  #51 (permalink)
Old 01-21-2015, 9:58 PM
Larry
Not sure how to picture this custom stand. Perhaps I will check scanner master or some for a stand but my solution will be to get a full size desktop scanner maybe HP-2 or if Whistler comes out with something.
I don't like having to move handheld scanner on a constant basis between car and house and screwing and unscrewing antenna since this puts unneccesary wear on antenna connector on scanner.
  #52 (permalink)
Old 01-21-2015, 11:12 PM
marcotor's Avatar
Default If cost
Is a barrier, this is two 99 cent card holders, lashed together. Works just fine for my needs, as these
are across the room and I have no trouble with stability or reading the displays with my tired eyes.
Being a lifelong Californian, I took a minute to secure the card holders to the top of the BCT15x at the
top of the rack with a tiny bit of Quake Hold.
I have one of the hand built stands on order, should be here next week. If it is all it appears to be, I will order a few for my (too many) handhelds
Impressive Scanner/Radio list:
  #53 (permalink)
Old 01-22-2015, 12:49 AM
nICE and inexpensive. Where did you get those card holders?
  #54 (permalink)
Old 01-22-2015, 9:21 AM
marcotor's Avatar
.99 Cents Only Store
  #55 (permalink)
Old 01-22-2015, 1:54 PM
jonwienke's Avatar
RAM mounts solve the first problem. Get one with a suction cup if you don't want to use screws.
Amazon.com: Ram Mount RAM-HOL-UN4U Universal Finger-Grip Phone or Radio Holder (Black): GPS & Navigation
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
The second problem isn't one. Use the BNC adapters that came with the scanner and ST-2, and all the wear from connecting and disconnecting cables gets put on the adapters, not the scanner itself. And it will be faster.
  #56 (permalink)
Old 01-22-2015, 2:02 PM
Originally Posted by bearcatrp View Post
I want one like this, listens to P25 1 and 2, and about everything else.
IC-R9500 Communications Receiver - Features - Icom America
a 14000 dollar receiver that you need to buy a digital card for to hear P25.. no thanks.
My Scanners: BCD396T, BC246T, BCT15 (2), BCT15X, BC346XT, BCD996T, BCD996XT (2), HP-1, HP1E, PSR-800, BC125AT, BC536HP, BC436HP
  #57 (permalink)
Old 01-22-2015, 8:47 PM
Amazon.com: Ram Mount 2 x 1.7 Inches Base with 1-Inch Ball that Contains the Universal AMPs Hole Pattern for the Garmin zumo/TomTom Rider/Urban Rider: GPS & Navigation
Amazon.com: Ram Mount Composite Short Double Socket Arm for 1-Inch Ball Bases: GPS & Navigation
Amazon.com: RAM Twist-Lock Suction Cup Base with 1 inch Ball: Computers & Accessories
Thanks for that info.
Those first above items in Amazon are primarily for car use? If so that's fine too because I also need a secure mount for 436 until I get dedicated scanner for this older car either a HP-2 or Whistler?
My newer car has a cup holder and the base mount goes into that then has an arm that attaches to a cradle. Excellent car install and scanner is secured.
Now my older car has no cup holders. One of those mounts looks like a suction cup to attach to windshield but I can't imagine that being successful because of the shape of the handheld scanner 436 and location on windshield. For my old car, I could use a secure mount but not sure what it can mount to because there is nothing but plastic console and seat in the middle.
  #58 (permalink)
Old 01-22-2015, 10:43 PM
marcotor's Avatar
You could also consider a seat bolt mount. I have used them in a variety of applications, and they can be had nowadays for scanner/phone use for about $25 on Amazon, or even at mountguys.com
Here's the Amazon link for the one I am currently using: Amazon.com: Arkon Smartphone Seat Rail or Floor Car Truck Mount for Apple iPhone 6 Plus 6 5 5S 5C Samsung Galaxy Note 4 3 2 Galaxy S5 S4: Cell Phones & Accessories
Took me 5 minutes to install in my daily driver, and holds any of my handhelds fine with just the stock holder attached. I will add that the stock holder isn't enough for a 436 if you have one of the bulky cases.
Come to think of it, this comes with a plate for floor mounting, so you could mount it to a desk or table too.
  #59 (permalink)
Old 01-23-2015, 4:10 AM
jonwienke's Avatar
It's a completely modular system. The components I linked are what I use to secure my 436 to my coffee table at home. In my truck, I substituted a second ball mount plate for the suction cup, and bolted the ball mount plate to the center console. You can get longer connector clamp modules if you need, you can totally customize your mount to the device and the location by mixing and matching the components you buy.
  #60 (permalink)
Old 01-23-2015, 1:12 PM
dick122's Avatar
This is what I use. Have one in car and one in house. Work great.
Dick
BCD536HP
