Good Evening.
I am using 2 2500 MAH batteries for my scanner. But it seems the battery life even when I have the battery saver turned on is about 5 to 6 hours. And after that period of time I get the flashing battery on the upper right side of the screen and then eventually the scanner shuts off.
Is there any other ways that you can extend the battery life. It's pretty bad when you can't get at least 8 or more hours from the batteries. Any suggestions would be greatly appreciated. Mark Griffin, KB3Z
