KA2ZEY
With the release of DMR beta firmware for the BCD436/536HP scanners, I wanted to get some clarification of programming them manually outside the DMR Upgrade monster thread:
Given the fact that the beta might not be working 100%:
1) A single DMR frequency just requires DMR One Frequency system and you can either/or choose to enter Talk Group ID's or just Search. Color code is not an option yet.
2) A Connect + system requires MotoTrbo Trunk system and (must have LCN entered in?) Everything from DMR One Frequency is the same
3) A Capacity + system requires (same question as above)
4) MotoTrbo type III ?
5) In search mode, only the indication of the DMR type is indicated and demodulation if there is voice traffic with color code.
6) If one is doing a Custom Search and discovers a CAP or CON DMR system, how can one figure out the frequencies used without a database if at all?
