Since this is not widely seen, it doesn't make sense to limit to our normal beta testers (none are in San Diego, for instance). The process for doing the update during testing is more complicated than a public release. So, please read the below carefully.
Apply using BC_VUP for Beta: http://info.uniden.com/twiki/pub/PartnerWeb/BCD996P2_Beta/BC_VUP_BETA_TESTER_V3_02_01.zip
In case you don't have the serial driver: http://info.uniden.com/twiki/pub/PartnerWeb/BCD996P2_Beta/uniden_usbser.zip
And, the actual firmware payload files:
http://info.uniden.com/twiki/pub/UnidenMan4/BCD325P2FirmwareUpdate/BCDxxxP2_V1_07_00.zip
Even though the above links show a particular model #, they work for both models.
1) Make sure you've installed the serial driver (your scanner will be assigned to a COM port when you plug it in).
2) Unzip and install the Beta version of BC_VUP.
3) Unzip the firmware payload file (2 files inside, one for each model).
4) Run the beta version of BC_VUP and follow the prompts to select the payload file for your model and apply it to your scanner.
A few comments:
a) No, I do not publicly comment on pending updates until we are ready to comment on pending updates.
b) Emails received asking whether we will do a particular update are deleted unanswered.
c) Phone call messages received asking whether we will do a particular update are not returned.
Please post results to this thread.
A few comments:
