This is not an official release, and no one needs to use it (other than those who want to check against the specific issues addressed). It is for testing/checking. Once we get results from this, we will release an actual update at some point.
This specifically is in regards to the threads at http://forums.radioreference.com/un...ceived-until-analyze-mode-entered-exited.html and the posts mixed into the thread at http://forums.radioreference.com/uniden-tech-support/337355-dmr-public-release.html regarding slow DMR One-Frequency Trunking scanning. I'll put "pointer" posts in those threads so that replies can move here.
Firmware files are at:
BCD536HP TEST FIRMWARE 1.11.21
BCD436HP TEST FIRMWARE 1.11.21
Install by copying the appropriate bin file to your scanner's firmware folder then cycling power.
DMR OFT scan speed should be more comparable to programming in conventional mode.
For the other issue (band plan not populating), we need a log file in a different format. This firmware creates the kind of log file we need. Use the instructions I provided in the other thread to create a log and attach it to this thread.
