Just a quick question about Uniden Priority scan. I've owned a BCD996P2 for quite some time now and it's a beautiful scanner. It works perfectly except for one function, it's analog priority scan. It's remarkably slow, as in it pauses to check the priority channel for enough time to make any digital traffic unintelligible and analog traffic difficult to understand. All of the Motorola radios that I own have a priority scan that you almost wont notice because its so quick. I only have 1 priority channel that it should be checking. Any tips for speeding up the scan? I have a BCT15X with the same problem. I've programmed both with bluetel software, I can make the codeplugs available if it helps.
