Eugene
Greetings. I have 1 396XT which previously had Firmware 1.08.14 and I updated to 1.11.01. Now it will not track VA State STARS system worth a damn. It takes longer to capture a control channel, will bounce around from "NFM" to a totally different CC, Back to NFM then back to the original CC. While on a control channel, I have a PRO 197 programmed to the same system. The PRO 197 has the telescoping whip set at 15" and the 396XT has a tuned 2M ham duck, so they are on a similar footing antenna wise. The PRO 197 will be having traffic while the Uniden, in the same part of the house, will show a control channel but no traffic. I am now missing > 2/3 of the radio traffic which was not the case before the update. Since it worked fine before the update and now won't, I have to assume it was something with the update. How can I roll it back to 1.08.14 as it is pretty much worthless now for the STARS. Thanks in advance.
Eugene KG4AVE
Eugene KG4AVE
