devicelab
Whacker Extraordinaire
Guys, I'm baffled. BCD996P2 /w firmware 1.07.09
Problem: DMR is NOT detected whatsoever during custom search
Resolution: Full reset of BCD996P2. I'm now able to custom search AND detect DMR systems properly
Problem 2: When I load my Freescan DB into the BCD996P2 it breaks the above issue. No matter what setting I change it will NOT detect DMR during a custom scan.
Now I looked at my Freescan DB and the only thing that was off (compared to the full-reset default of firmware 1.07.09) is the 400ms default wait time; however, when I changed this on the scanner directly, it still didn't resolve the problem. Nothing worked until I did the full reset.
Question: could Freescan be killing my DMR somehow? Or is this simply a scanner setting?
Notes: I looked for a long time and couldn't find anything that would fix this... I know for DMR detection (in the past) I had to set the modulation to AUTO or it wouldn't detect. (The firmware default is also AUTO modulation.)
