Have a BC536HP, used the Sentinel software to load the freqs, for Boston Logan Airport, but when I put them in their own fav.s list, and enable that list, the scanner says "no channels to scan". Thoughts?
I assume you are referring to AM air frequencies. Check your 'Service Types' settings and make sure 'Aircraft' is enabled. If you mean business frequencies make sure 'Business" is enabled. The HP scanners default to Police and Fire / EMS service types and sometimes when creating FLs they default to 'Custom 1".
