BC125AT: newbie having trouble......
koebes
I have a new bc125 scanner. I'm having trouble listening to my local PD. According to the frequency listing I should be able to hear them. They are available on my scanner app....broadcatify.
155.73000 KNEN601 RM 136.5 PL PUTNAM SO Sheriff - Dispatch FMN Law Dispatch
Could they have gone digital or am i not setting the scanner up correctly....
Thanks for any help...
Steve
PS. Putnam County Ohio Sheriff Department is what I'm trying to listen to.
troymail
Silent Key
Steve
Possibly using the state system and the conventional channel is backup or no longer in use?
https://www.radioreference.com/apps/db/?sid=6643
If they are digital now, I don't think the BC125 will work as it is an analog non-trunking scanner.
wbswetnam
DMR-istan
That's my guess is that they primarily dispatch on the Ohio MARCS system. My local sheriff's department also has its conventional VHF frequencies listed in the database, but they only use them very rarely as a backup or for giving out BOLOs. The sheriff's department uses the state AWIN system probably 99.9% of the time.
budevans
Cleveland, Ohio
Steve
There are two listings for the Putnam County Sheriff Dept.
The first is the Conventional frequency you posted.
The second is a Talk Group on the Ohio MARCS-IP system:
54843 d63b D SO69DISP Sheriff Dispatch Law Dispatch.
For information regarding Putnam County, I'd suggest that you post your question on the Ohio Forum.
https://forums.radioreference.com/ohio-radio-discussion-forum/
