I could use some help. I seem to be missing a step or two.
My local Type 2 system is being migrated to a P25 Phase 1 system.
(old) Type 2 system: https://www.radioreference.com/apps/db/?sid=2707
(new) P25 system: https://www.radioreference.com/apps/db/?sid=7791
A few years ago, the type 2 system went through rebanding in case that is important. The migration is seeing frequencies slide over from the old system to the new one.
I set bank 1 as Type 2/P25 800. Status bit off, End Code enabled. Programmed only the one freq that is the current control channel. Did not enable control channel only, no bank plan. Digital card enabled.
I can see the radio try to switch to a voice channel, but it just moves right back to the control channel.
I suspect the problem is has something to do with switching to the correct voice frequency, but can't seem to figure out what I have missed.
Can someone help out?
Thanks!
Thanks!
