  #21 (permalink)
Old 03-08-2018, 9:11 AM
iz0kvz's Avatar
Originally Posted by Ubbe View Post
The antenna are made for the US frequencies that might not be optimum for european monitoring.
Look at UPmans measurements of other antennas performance relative to the stock one.
Measuring Relative Antenna Receive Performance - Massively Uninformed
One can see that the stock antenna seems to be tuned to 175Mhz and 415MHz.
/Ubbe
Hi all,
I made a couple of tests in VHF too; in the attached pictures the radio on the right has the original antenna and the 3600 has a more performing diamond SRH-36 antenna.
Test 1) S 5 and perfect audio with the radio on the right, almost unreadable audio and no bars on my 3600.
Test 2) S 7 and perfect audio with the radio on the right, very noisy audio and 2 bars on my 3600.
Please make Your considerations.
Thanks.
Size:  52.1 KBName:  IMG_9934.jpg
Best regards,
Tony - iz0kvz
Tags
3600xlt, dmr programming, europe, support, uniden
