working on Identifying some systems in the Memphis area tonight, so in the process of entering them into the 536HP i am noticing some anomalies, and i am hoping i am doing something incorrect.
in the video i have the system set up as follows in the 536HP
461.1 LCN 1
461.675 LCN 3
464.9125 LCN 5
these were verified with the analyzer as well, and as you can see DSD is tracking just fine
it seems if there is a rest channel the scanner will sit on it as it is supposed to, however
this is where it gets wonky
if a transmission occurs on the same channel as the rest channel, everything is fine
if the transmission occurs on another channel more than likely it will not pick up the transmission, if you sit on a particular talkgroup it does increase the odds of hearing a transmission but not always, id search is always iffy
am i missing something, this is the last firmware, good signal,but i am lost
Thanks in advance
https://www.youtube.com/watch?v=6ETBVOfLiuI
461.1 LCN 1
461.675 LCN 3
464.9125 LCN 5
Thanks in advance
