On the 996p2 / 325p2:
Is there a way to scan p25 phase 2 tdma voice frequencies as conventional?
To combat simulcast distortion?
Just curious, how would this "combat simulcast distortion"?
If not, upman can they add it down the road? Kind of like the dmr conventional.
I understand the OP's concept, let's try monitoring the channels as conventional rather than trunked mode to see if it will work better for LSM. I assume that he has a Phase 2 system there.
As an aside here, AFAIK there are no P25 radios that will allow one to use TDMA in a conventional mode. I don't ever recall seeing that option in the APX software and have never heard of it being done.
see above.I suppose it is possible, they are doing that with DMR so why not P25?
If it happens to become a thing I would imagine that Uniden (and Whistler) would respond and add that to scanners.
Yes, as I alluded to later in my post. Good idea for something to try but it wasn't the issue or solution.It’s a hardware issue, not something that can be changed by changing programming.Originally Posted by N9JIG
That hasn't stopped Motorola from "adding features" that seem to restrict systems to their radios and exclude others. There is nothing stopping Motorola or the others from implementing this if they choose to.Conventional TDMA, and TDMA on simplex has not been written into the P25 standards, there fore it is not available on P25 subscribers.Originally Posted by N9JIG
My whistler WS1080 has an option in the search menu for Phase 2 along with Phase1 and DMR. Not sure if it decodes the voice, or if it just finds P2 Voice channels I have never tried it.
I now understand that the OP was going to input the input frequencies (which would not be subject to simulcast since it is one signal coming from a single location). However, such signals are severely range restricted and are typically blocked by terrain within a couple of miles (unless you have a tower-mounted antenna). And, they aren't decoded by scanners.
Even if you did, and no reason at all, what about the other 4,5, or 6 of the trunked freqs? You would need to have every one to follow anything.Sorry for any confusion in this matter. But it is the repeater output freqs from the sites that i'm referring to.
Ie 859.7125
Thanks for all the input here
