troymail
Silent Key
Paul -
I mentioned this in NC discussions but since it still isn't getting any better, I opted to toss this out here to ensure it is being addressed.
I'm monitoring a single frequency NXDN system along with a conventional NXDN channel. Yesterday, I also added 4-5 conventional frequencies that might be analog but are planned/recently licensed for NXDN (had to set them to "Digital Only" to overcome the analog squelch issue).
Anyway - watching the radio, I see the most solid 5 bars you can imagine when the single frequency NXDN system is being scanned - I assume because the frequency is both control and voice. Point being, however, is that the signal is SOLID.
And, yet, I've yet to solid reception of voice calls on this system. I have a TRX-1 sitting here also that is regularly hearing voice calls on this system (as well as the known active NXDN conventional channel) - some fairly lengthy - and the 436 misses well over 90% of that voice activity when I clearly see it scanning through the system at 5 bars. This situation if exhibiting the kinds of things I've seen in the past on simulcast systems but I'm fairly confident that this isn't any type of simulcast issue.
I have tried quite a number of things to see if I could pinpoint situations that are better than others -- HOLD on the system/site, switch threshold settings to MAN, HOLD on the single TGID, program a range of hundreds of TGIDs (most are unknown), switch from ID Search to ID Scan, etc. and I've not been able to make this much better if at all.
Obviously, this started with the initial NXDN firmware (1.14) and 1.15 isn't any better.
If you want a capture of something to look at, let me know (how).
Edit (0926): just installed 1.16 but given it's only a fix for the squlech bug, I'm not expecting much change....
