I got my GPS unit today (Thanks JonWienke) and played around with it for a little while and seems to be working great on the Full database. But I have about 85 entries in my favorites list and very few of them don't have coordinates because they are not in the database yet. I see that that each system, when you go to edit it, under the options tab, there's a location control pull down menu with yes or no. Are each entry in the favorites list independent and can I turn on location control for the ones that I have GPS coordinates entered, and leave the reast of them off, and during a gps scan of the favorites list, will all the ones set to off be scanned no matter what? Some of the systems that I have programmed I haven't been able to identify what or where they are, so adding coordinates would not be accurate. Most of my favorites are set up to where the main system with known frequencies are programmed as a trunk system, and then after that I have the same system programmed as conventional with maybe more frequencies that might be part of that system. I believe you can enter coordinates into a conventional list, but all frequencies in that list can only have 1 coordinate programmed to it. I'm new to this GPS scanning and any help, tips would be appreciated.
So my main question is what would happen if I program some with coordinates and turn location control on for only those, and keep the others off. Would the ones that are off still be scanned? Thanks!
