We aren't able to duplicate the issue, but have isolated possible causes down to 4 areas. To check, we've made 4 test updates. If you are experiencing the issue (noise after the end of digital transmissions when remote monitoring), we'd appreciate it if you would check with each of the test version s and let us know which one(s) fixed the issue.
To test, copy the target update into the scanner's firmware folder, then reboot the scanner.
(One at a time...)
http://info.uniden.com/twiki/pub/PartnerWeb/Firmware/BCD536HP_V1_16_01.bin
http://info.uniden.com/twiki/pub/PartnerWeb/Firmware/BCD536HP_V1_16_02.bin
http://info.uniden.com/twiki/pub/PartnerWeb/Firmware/BCD536HP_V1_16_03.bin
http://info.uniden.com/twiki/pub/PartnerWeb/Firmware/BCD536HP_V1_16_04.bin
(One at a time...)
