Mobilman44
- Joined
- Apr 15, 2018
- Messages
- 98
Good Day!
I've had (and used) the 436 for two weeks now. I picked up a second antenna (Diamond srh77ca) and believe I notice an improvement in reception - although its hard to say for sure.
So far my scanning revolves around my zip code (77388 - north Harris County Texas) and I can pick up a good mix of law enforcement, EMS, and fire.
The quality of the transmissions ranges from extremely good, to clipped and muddled. Most transmissions seem to be somewhere in between.
I plugged in some Bose headphones and found the sound clarity significantly improved. Would I get similar improvement with a plug in speaker?
Also, I would like to know if the "clipped" messages are caused by the participants, my reception, or ?
Clarity is another issue, but that could well be "normal".
Having done two "ride along" shifts with my Nephew when he was a training officer, I learned then that the transmissions received in the squad were rarely clear to my ear. I guess it takes time to get used to.
Anyway, other than a really good outdoor antenna, is there any way to improve on reception and clarity?
Thank you!
Thank you!
