The jacks are standard USB mini and micro and the pinouts are widely available online.
The only quirk is that the GPS input goes to the ID pin (next to ground) of the USB mini jack.
Thanks Jon,
I'm still trying to figure out your comment on post #3 "The only quirk is that the GPS input goes to the ID pin (next to ground) of the USB mini jack"
ID is pin 4, which wire is this?
GlobalSat BU-353S4, I cut of the serial to USB end (uses the prolific driver)
So instead of instead of going to D+, solder tx to ID?
Do i have the equivalent now that I cut off the prolific chipset/USB plug?
