The lower jack is marked "Charge", the upper micro USB port is not labeled nor discussed in the manual. So the first attempt to interface the SDS100 to my laptop, I used a micro-USB cable that I had and nothing happened, then I watched the video on ScannerMaster and it showed using the supplied USB cable and connect it to the charge USB port. So what is the upper port for?
