Old 06-15-2018, 12:04 AM
Default Folder name of microSD card?
Does anyone know the name listed on the microSD card installed in the SDS100? I did a backup of the contents of the card when I first got the scanner, but failed to copy the folder name. The folder that Sentinal uses to write to on the PC is BCDx36HP. It is listed in the program in the documents folder as well.
I formatted the card but when I went to reload it I didn't have the folder name. I have it all working, but would like to use the proper file name.
Old 06-15-2018, 5:37 AM
jonwienke's Avatar
The folder name Sentinel uses (BCDx36HP) is the correct name.
