Have you turned charging while on in the settings menu?My two LED's do not work or lite up. Is there something I am missing in the setup?
Also I know the battery is cr_p, but after over 12 hours of charging, with the supplied adapyer, I only get 3.5 volts, is that the norm?
nope, I would figure charging led would be right out of the box working, I will look into that, as turned off and charging nothing lites.
Make sure charging while scanning is enabled. I noticed that, while I had it turned on, if I connected the scanner to a port that did not supply sufficient current to both charge the battery as well as power the scanner (specifically, a port on one of my PCs), that setting defaulted back to off. To get charge while scanning enabled, I had to do that once more in the menu.nope, I would figure charging led would be right out of the box working, I will look into that, as turned off and charging nothing lites.
Exactly. That's the behavior I noticed after I first goi the scanner. Not a big deal, but something to keep in mind if the scanner appears to be no longer charging.Any time you get a low USB voltage error, you have to re-enable the Charge While On setting.
I can't think of a good reason why those charging LED 's aren't lighting up. I'm away from my radio at the moment and can't check, but I don't believe there's a setting that will prevent the radio from charging or turn them off entirely.
If I remember correctly, my battery level says 4.2 volts when the the green light comes on indicating it's charged.
Not likely, but I can't help but wonder if you're getting all the power your adapter needs from your electrical outlet.
Someone else on this forum may have some better ides.
Good luck.
>> I mistakenly assumed his radio's LED's were staying dark even when it was turned off and plugged into the adapter, not while it was on and scanning.
This is correct.
While charging with the radio off, no led are lit.
I turned on charging while scanning, as stated, and still no difference.
Whether the scanner is on or off, charging or not, no working LED's
I will put on a different charger as the Uniden one may not be working correctly due to the 3.5 volts after 15 hours of charging while turned off.
3.5V is basically the mostly-discharged state in which the battery was shipped. If any charging happened, it would be between 4.1V and 4.2V. Try a different cable and/or USB charger.
What is the ambient temperature in the room where you're trying to charge?Different chargers and cables including the one in the box, at 3.49 volts the unit complains of low battery, so I dont get much life after that. I dropped the alarm to 3000mv and it stops complaining, due to the 3500mv threshold. Also after hours of charging the unit is still cold.
Time for this to go back.
