I noticed that the SDS100 has a hum sometimes while receiving analog communications. It sounds like an amp that has a bad ground. This is not present on the 436HP, TRX-1 or the 325P2.
See if you hear it listening to a weather channel. If not, it is CTCSS tone bleeding in. There normally should be a high pass filter in the radio to cut out tones below 200Hz.
If you hear it on a WX channel, are you using a charger and/or external antenna when receiving?
The SDS100 filters out DCS and CTCSS tones below 100Hz, but you can still hear the higher ones if listening with a speaker or headphones with decent bass response.
Not hearing it on a weather channel , and no charger with stock antenna. I will record audio files from the 436HP and SDS100 and upload them when I get a chance.
