Old 09-16-2018, 1:18 AM
737mech's Avatar
Question Power draw DC
What is the actual power draw of the BCD535HP on battery power? While scanning and catching hits etc'? Then add the Wifi Dongle more I assume? How much current does it use?
Old 09-16-2018, 3:15 AM
Post
Add this unit inline with your battery and you'll have all the answers you need...
https://powerwerx.com/watt-meter-ana...e-dc-bare-wire
Old 09-16-2018, 9:51 AM
UPMan's Avatar
Uniden Representative
The BCD536HP does not have batteries...
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 09-16-2018, 11:16 AM
What's the inline fuse size? It's less than that
SDS-100, BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000 and other RF capture devices
Old 09-16-2018, 11:38 AM
737mech's Avatar
Default DC power
The manual says the power supply is rated at 750mA. I'm trying to figure out how long I can run on a deep cycle battery for example one from an electric wheel chair? 12V 55aH less than 1A load = 55 hours or more?
Old 09-16-2018, 11:57 AM
you could get the item device lab has indicated or you can just use a ammeter in line either way once you know the max current draw the rest is simple math. I would do measurements with full volume on an active channel all display setting set to max just to get a worst case value.
Old 09-16-2018, 12:01 PM
Code:
BCD536HP DC Current Drain
Radio State     Backlight       Volume  VDC     mA
Off             ----            ----    13.547  0.42
Conv scan       High            Min     13.386  188
Conv scan       Low             Min     13.399  168
Conv scan       Off             Min     13.407  162
Hold channel    High            Min     13.390  187
Hold channel    High            10*     13.386  189
Hold channel    High            Min     13.339  243     WI-Fi plugged in
*Holding on conventional channel, squelch at 0, noise output to speaker
Voltage measured with Fluke 187, current with Fluke 8050A
Old 09-16-2018, 12:13 PM
737mech's Avatar
Originally Posted by pro92b View Post
Code:
Thank you! Great help!!
