Old 09-16-2018, 3:40 PM
Default SDS100 Stopped working
I have a SDS100 and was working great until the last firmware update. I have main version 1.05.00, sub version 1.01.05 serial 38326088000919-0F6 installed and now scanner doesn't work any longer. Even when scanning nothing and display is blank showing nothing is being scanned; I hear a "crunch, crunch, crunch" rhythmic sound. I was working fine before when I firmware was updated. Any idea how to fix it now that it is broken. This is a desk scanner and has never been taken out of my house and received no abuse. I have restored it and still doesn't the absolute same thing.
Old 09-16-2018, 5:49 PM
troymail's Avatar
Silent Key
Sounds similar to other reported failures ("crunch" noise).... Looks like it is in need of a trip back to Uniden...
https://forums.radioreference.com/un...went-deaf.html
Unication G5(UHF)
Old 09-17-2018, 7:35 AM
NWI_Scanner_Guy's Avatar
Damn, the more of these "my SDS100 stopped working" threads I read, the more I cross my fingers and pray every time I turn mine on.
o_O
BCT-15X / PRO-2051 / BC-355N
SDS-100 / BC-246T / BC-125AT / PRO-107 / PRO-137
ALINCO DR-605T / TYT MD-UV380 / UV-5x3 / UV-82HP / UV-82X
Old 09-18-2018, 12:15 PM
Thank you and it does sound like the others comments. I am going to contact uniden and send it back.
Old 09-18-2018, 12:24 PM
diskmonger's Avatar
Sounds like this SDS100 is a real clunker...
Old 09-18-2018, 12:33 PM
mule1075's Avatar
It's not.
Uniden SDS100/780XLT Motorola HT1000/GM360 Whistler TRX-1
Old 09-18-2018, 12:54 PM
KR7CQ's Avatar
Yup it does. Another one bites the dust it seems.
Old 09-18-2018, 1:24 PM
I spoke with Uniden and they said I am the first they have heard of that has had this problem and they recommend that anyone else having the same issue needs to call them at 800-297-1023 Select Option 2 then again option 2 when prompted and explain your problem. The tech talked me thru a few things and still have the same issues. He recommended waiting for his Supervisor to email me but If I want send it in now. These were my only 2 options was wait or send in.
Old 09-18-2018, 1:26 PM
What I feel from my experience it is a corrupt firmware update or like he said I could have updated it with a 436 as the target. I don't think I did but I am only human.
Old 09-18-2018, 1:44 PM
troymail's Avatar
Silent Key
It's under warranty... I'd send it in with a very clear description of how well it worked (or not) and then what changed.... be as complete and clear as possible.
But... that's really your decision...
Unication G5(UHF)
Old 09-18-2018, 1:55 PM
seth21w's Avatar
What was the firmware before you updated and did you do the update through sentinel or did you do the beta, and copy the firmware file into the sds drive? I find it hard to believe the firmware could cause this.
Unication G4 Uniden SDS100 Tytera MD390G RTL SDR
Old 09-18-2018, 2:01 PM
I believe that UpMan has stated several times that it is NOT possible to install a firmware (ex. for the 436) into a 536 or SDS100 radio.
Old 09-18-2018, 2:14 PM
UPMan's Avatar
Uniden Representative
It is also not possible to have a "bad firmware update." Checksum would fail and the update would never be applied.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
Old 09-18-2018, 4:52 PM
it is going to be one with UPS. it's outta here... the final verdict
Old 09-19-2018, 10:38 AM
UPMan's Avatar
Nothing about a f/w update would cause what is described. It is likely that whatever happened coincidentally happened around the time an update was made. In any event, it is a repair issue.
Personal Blog
Old 09-19-2018, 10:44 AM
mancow's Avatar
It sounds like the static protection devices are doing their jobs.
Old 10-30-2018, 6:53 PM
either way that sucker is in Texas now. When it comes back all dispatches with be with an awesome Texas twang accent.... as long as it works.
Old 10-31-2018, 2:12 PM
This. By doing so it allows us to track an issue. and see if there is a root cause.
