Release Notes:
1. Fixed freezing issue over 1000 sessions (sub folders) in user recording mode. This might also affect the reboot issue.
2. Support decoding for Late Entry code of CapMax.
3. Modified operations of LCN Finder for CapMax.
4. Modified DMR TGID validation method.
http://info.uniden.com/twiki/pub/PartnerWeb/Firmware/SDS100-1.06.00M-1.01.05S.zip
To apply:
1. Connect the scanner in Mass Storage mode.
2. Unzip the above linked file and copy the filesto the scanner's \BCDx36HP\firmware folder.*
3. Disconnect the scanner from the PC.
* Note that there is no change to the Sub firmware in this version. If your scanner already has Sub firmware v1.01.05, you can copy just the Main 1.25.00 firmware in Step 2.
To apply:
