Old 01-09-2012, 7:19 PM
NFR85's Avatar
Default BCD996XT Freq not showing on scanner display
I programmed a bunch of frequencies in via ARC XT scanner software. For Nashua it displays it on the bottom near SO and GRP but the other frequencies it doesnít show it. I have it labeled to what Iím listening to IE Lowell Fire.
Old 01-09-2012, 9:02 PM
torontokris's Avatar
Try to HOLD then FUNC (push silver scroll wheel) + 6 (disp) to change display modes
Easier to Read BCD996XT Digital Scanner Manual or ID display
Easier to Read BCD996XT Digital Scanner Manual mode
996P2 HP-1e HP-2 436HP 536HP WS1080 396XT PSR-500/600/800
Old 01-10-2012, 2:09 PM
NFR85's Avatar
Tried that all I got was Miltary Aircraft ECT. The manual doesnt help either very confusing
Old 01-10-2012, 10:02 PM
hfxChris's Avatar
If you hold and push func + 6, does the scanner even confirm that it is cycling between display modes 1, 2 and 3? What does it say on the screen when you try and do that?
Pro-97 | Pro-137 | Pro-2055 | BCD396XT | BCT15X | BCD996XT | HP-1 | Kenwood R1000 | R820T | Afedri SDR-Net
Old 01-12-2012, 4:41 PM
NFR85's Avatar
it doesnt cycle unless I manually do it when i hold it on Mode 1 says SID: 7C25h-0001
Old 01-12-2012, 6:14 PM
CoolCat's Avatar
The scanner must be in "HOLD" mode (not scanning) first before you can use the secondary function keys.
-Chris
I'll keep my freedom, my guns, and my money. You can keep the "change".
Old 01-12-2012, 6:53 PM
NFR85's Avatar
It was on the hold mode
Old 01-12-2012, 6:54 PM
NFR85's Avatar
Seems like its showing the freq on the bottom. I'll keep you posted
Tags
bcd996xt, display, frequencies
