dkohler
Hi,I have BCD396T and no longer can listen to Lake County,Oh anymore. the last time I listened was this winter. It looks like they may have done something in April.
Thanks Dan
Thanks Dan
I am not sure what you had programmed into your scanner before but they may have changed frequencies, rebanded or joined MARCS. But here is a link (below) that I found but not sure if this will help you or not. I'm sure some one will be able to help you out on this forum.Hi,I have BCD396T and no longer can listen to Lake County,Oh anymore. the last time I listened was this winter. It looks like they may have done something in April.
Thanks Dan
Post #43 in this thread:
http://forums.radioreference.com/oh...ounty-ohio-scanner-problem-9-27-2011-a-3.html
States that they moved to the MARCS P25 X2-TDMA system.
If you want to continue scanning it, you need a GRE PSR-800.
Is there a differance between the t and the xt? Maybe my BCD396T will not work anymore.The last time I used it was in the winter this year.I still get Geauga County.
It looks like I need a currant control channel,it does not seem to have the correct one.I downloaded the info of the website last nite but still looks for a control channel
Lake County is now on the MARCS-IP P25 system. They have shutdown their Moto Type II system.
You will need to setup or download the new Lake County MARCS-IP P25 system.
Here are the differences, Project 25 Trunking vs Moto Type II, All new TG (Talk Groups), New Control Channels.
So just changing the control channels on the old system setup won't work.
I guess I will have to wait for Radio Reference update there Lake County site.
Thanks Dan
