After listening to the local police department for many years when they operated in the UHF band, I recently had to upgrade to a new scanner when the PD switched to a P25 system.
I chose the BCD396XT, because I have had good luck with Uniden scanners in the past (had 4 assorted Unidens in the past).
Before purchasing, I read many reviews which stated how complicated programming of this product could be, but I thought I'd be able to figure it out.
I know that the receiver can be programmed using a computer and software, but for the present time, I am interested in monitoring only the local PD, and figured that I could program that manually. But I'm a bit embarrassed to admit that, after following several well-written sets of instructions over the past week-and-a-half, I haven't succeeded.
Is there any source with step-by-step instructions which would guide me in setting up the scanner so I can turn it on with it going directly to that PD, even if it means removing all of the pre-programming?
Thanks in advance for any suggestions.
In addition to the "Easier to Read" manual, linked above by Ensnared, there are additional articles in the Wiki here on RadioReference that you might find helpful.
Programming Your Uniden Scanner - The RadioReference Wiki
Uniden DMA FAQ - The RadioReference Wiki
Besides the articles themselves, each have links to additional pages with more information.
This
page (linked in the above), has step by step instructions on creating systems in a DMA scanner (that is the memory type that includes your 396XT).
For the 'Easier to Read' manual, the instructions for programming a Conventional system (one where the channels are not part of a trunked radio system) are
here.
Just below that are instructions for programming the various types of
Trunked systems.
The older scanners, whether Uniden (or Bearcat), Radio Shack, or GRE (which made many of Radio Shack's models) used banks & channels. You had a specific number of channels, divided among a certain # of banks. You had one trunked radio system in a bank (for the most part), and conventional channels, maybe divided up by area or departments. You either had the bank "on" or locked out, or maybe just a few channels disabled.
With the newer DMA scanners, such as your
396XT, you no longer have banks; you have
systems, groups, and sites. You can have up to 500 systems, up to 25,000 channels, and up to 20 groups per system. You have 100 System/Site quick keys that can be used to easily toggle a specific System (Conventional frequencies), or Site (Trunked radio system), on or off.
When setting up & entering programming, consider how your text tags will look.
For Conventional Systems, your display would be:
System Name <<alternating with>> Group Name
Channel text tag
For a Trunked System, the display would be:
Site Name......<<alternating with>> Group Name
Talkgroup ID text tag
For more on what displays, and additional choices with Display Modes, see
this.
Most of the pre-programmed systems are far outdated, and could be deleted. However, they can serve as some illustration as to how a programmed system looks, for those new to a DMA scanner.
I realize you want to program the scanner by hand, without software. However, software does have it's advantages, especially for those upgrading to a newer model. Besides being much faster to program, typing in frequencies and text tags, you also are seeing most, if not all, of the information at one time. This makes it much easier to spot and correct minor errors and omissions in data entry than stepping through multiple screens on the scanner itself.
FreeSCAN does the job nicely. (Use the
download link on that page.)
If, after reviewing the above, you are still stumped, I would suggest that you might ask, in the Illinois Forum, if someone has a FreeSCAN file that covers your area. Or, you can also shoot me a pm, with your email address. Specify what you'd like in a file, and I'll set you up a FreeSCAN file. The idea is to get you up & listening. Once that is done, then you can try your hand at adding additional agencies or systems. As you become more comfortable with the DMA system, you'll be able to do this without software if so desired.
