It may have been addrerssed, but seaching has not found the answer to these question?:
CAN the Argent HP-1 combo be used directly (for example) on the front USB ports on the BCT15 and/or BC996T for FRONT-PLUG GPS input?- Or will it "blow up" ;-) - Is there an adaptor from the hp-1 PLUG to standard 9-pin that mates with the rear socket.
ALSO: Is here sufficent compatability or function in the Argent HP-1 combo output to be used for APRS devices (Ham) assuming connector matching can be bought or fabricated?
reason: I just bought the Argent Hp-1 combo and will only need to use it on trips, which I rarely take except 1-2 times/year.
TNX es 73
Tom
W4NOV (.com)
TNX es 73
Tom
W4NOV (.com)
