milligandw
Hello All,
I just went through the firmware update (Uniden BC796D) and followed the Programming a Rebanded Motorola System instructions per: http://info.uniden.com/twiki/bin/view/UnidenMan4/BC796DFirmwareUpdate
However, although I'm able to receive the UMESC talkgroups now, I'm wanted to ask whether or not "Band Plan (BN)" and "Configuration Block Number (CBN)" are synonymous.
I ask because when manually programming my BC796D I didn't see any options specifically referring to "Band Plan" whereas every other setting was consistent with the instructions, i.e., upper/lower base freq, offset, spacing and polarity.
So I simply assumed that:
Configuration Block Number 1 = Band Plan 1 and
Configuration Block Number 2 = Band Plan 2
Any feedback would greatly appreciated.
Thanks!
Thanks!
