The RadioReference.com Forums
-   Uniden Thread Archives (https://forums.radioreference.com/uniden-thread-archives/)
-   -   BCD536HP Discussion Thread (https://forums.radioreference.com/uniden-thread-archives/278121-bcd536hp-discussion-thread.html)
KE4ZNR 11-16-2013 12:28 PM
http://i.imgur.com/Sl2xyv6.jpg
BCD536HP Mobile, Wifi, and More
TheBCD536HP is Uniden's new flagship mobile scanner...which incorporates two firsts. Like the BCD436HP, it is the first standard mobile scanner to include the ease of use of the HomePatrol-style database; simply enter your zip code and away you go. But, the BCD536HP adds to that WiFi connectivity, allowing you to listen to and control your scanner using your smartphone or tablet...from anywhere in your home, vehicle, or around the world.
4 Gigabyte microSD card holds the entire USA and Canada database of radio systems, plus leaves room for hundreds of hours of audio recording.
Programmable Alert LED lets you set a specific color to alert you when a channel becomes active.
TrunkTracker V with support for APCO Project 25 Phase I and Phase II, X2-TDMA, Motorola, EDACS, and LTR Trunked Radio Systems
Quick Key access to 100 Favorites Lists, 100 Systems per Favorites List, and 100 Departments per System.
Discovery Modes help you find new channels on trunked systems and frequency ranges.
Analysis Modes include Band Scope, RF Power Plot, Trunked System Analysis, and EDACS/LTR LCN Finder.
Flexible Easy Channel Selection using Zip Code or GPS and Service Types — just pick the kinds of channels you want to hear and tell the BCD536HP where you are and let it do the rest.
Easy Scan Control using the dedicated System, Department and Channel Hold buttons.
Complete Front-Panel Programmability — create custom Favorites Lists either using systems from the main database as a starting point or program your systems from scratch.
Temporary Avoid lets you quickly silence unwanted systems, departments, or channels while allowing you to restore them by cycling power.
Backlight-on-Squelch option allows the backlight to remain on during an entire transmission.
Date/Time indication on display with time stamping for recordings.
Trunked and Conventional Channel Priority with Priority Do-Not-Disturb
Close Call® RF Capture with Do-Not-Disturb automatically tunes the scanner to nearby transmissions without interrupting reception in progress.
NOAA Weather Alert with SAME
Two-Tone Paging with up to 32 tone slots
Flexible Scanning — scan from any combination of the main database and Favorites Lists
Included Sentinel Software makes database and firmware updates simple. Also allows you to create, edit, and manage your Favorites Lists.
USB PC Connectivity
Serial GPS input for location-based scanning useing the Uniden GC-GPSK or other compatible GPS receiver.
64 x 288-Pixel Dot-Matrix Display
Backlit Display and Keypad
Printed manual in the box with online updates.
Available January, 2014
Uniden New Scanners Info Site
Uniden BCD536HP Spec Sheet in Adobe Acrobat PDF format.
Uniden BCD436HP & BCD536HP Owners manual in Adobe Acrobat PDF format
Sentinel software program companion to the BCD436HP/BCD536HP.
cmartellw 11-16-2013 12:30 PM
Pre order
Any idea when Scanner Master will start taking preorders?
scosgt 11-16-2013 12:32 PM
Does the display have any color besides blue?
K4MCO 11-16-2013 12:33 PM
Anybody got that link he mentioned?????
kman 11-16-2013 12:40 PM
So will you be able to stream the sound direct from the BCD536HP thought your home Wifi to your cell phone that is out with you on the road? IT was not clear sounds like you can for sure do it in your house?
bear780ks 11-16-2013 12:40 PM
I'm Really liking that Scanner it looks so Dressed up..
http://info.uniden.com/NewScanners
blantonl 11-16-2013 12:41 PM
Here is a video of the new scanner in action. It it a truly impressive radio.
The new Uniden BCD536HP in action - YouTube
PhillyPhoto 11-16-2013 12:43 PM
So since they put a mini USB connector on the front, I guess I'm SOL as far as a remote head goes? I doubt the old ones will work, and with their push for the phone app over WiFi I'm not sure that we'll see a replacement head come out.
milf 11-16-2013 12:43 PM
Again Phase II way after it was needed, no DMR, no NXDN, no LTR Pass Port, no LTR Multinet, no proper support for multisite P25..... Other than that, awesome tool.. Would play with one, but... Not on the ball. Will wait to see just what Whistler puts out in its 3 or 4 in 2014.
K4MCO 11-16-2013 12:43 PM
Thanks Kman
bear780ks 11-16-2013 12:44 PM
We'll be Looking Thanks Mr. B
brennank 11-16-2013 12:44 PM
Originally Posted by kman (Post 2071762)
They are a little slammed at the moment, so don't expect it to work.
I for one will be getting this bad boy. Hopefully it is a 1DIN scanner aswell so I can easily slide out my 15x and slip this right in. Looks amazing. Nice work Uniden.
As much as I would like to see a lower price this is honestly fair and I am happy with it.
I am interested to see how it programs. I have no experience with any of the home patrols scanners. I have grown to like FreeScan, so hopefully we can still have some power user software to take full control of the scanner. I never program mine without the software, too damn complicated.
markbart 11-16-2013 12:46 PM
Drool!!!!!!
airwolfbell222 11-16-2013 12:47 PM
Thanks for posting the video, does it have a kickstand? Does it cover 225-380mhz?
Franz
Jay911 11-16-2013 12:48 PM
Good lord, why is that such a big deal? Get a cheap Android tablet and mount it in your vehicle. Now (with the wifi feature) you have a remote head.
kf4lhp 11-16-2013 12:50 PM
Let me be blunt... no TRBO, no NEXEDGE... I'll pass.
ofd8001 11-16-2013 12:51 PM
Anything on whether this model is a little more "friendly" on the simulcast system distortion problem?
Also, they mention "Motorola" separately from the APCO type 1 and 2 systems. Isn't TRBO a Motorola thing therefore the new model will receive such?
blantonl 11-16-2013 12:51 PM
No you won't. You'll buy one - you know you will...
DaveIN 11-16-2013 12:52 PM
Exactly! "World without wires". Sounds like a good idea to me...:twisted:
