I've got a BC780XLT with the loud volume problem that I'm sure has been discussed on this board before. I can set the volume control at whatever level and without warning the volume increases to the maximum level. When this happens the volume control does not work. The only way I've found to "correct" this is the bang on the radio. Then it will return to the previously set level and everything works great.
I seem to remember that it was a grounding problem or something with the volume control switch. Someone had come up with a fix for this issue. Doing a search of the forums did not turn up anything.
Can someone recall what could be done to fix this and how to do it? It is very frustrating to say the least. It happened this morning to me after three months of no problems. So now it is time to do something about it!!
Thank you ahead of time.
