I need to reset my scanner bcd996t, i went to install new firmwear and now it just "blinks" when i turn it on. How do you reset it? Thanks. oh boy......
Scanner ResetTo initialize the scanner's memory, turn off the scanner. Then press 2, 9, and Hold while turning it on. The scanner will give you the option 'Restore Preprogram List? "Yes"=E/No="."', if you say 'Yes', the scanner reloads the preprogrammed systems.Important! This deletes all preprogrammed data.copied from a link you may find useful: http://myweb.cableone.net/marksscanners/996/996.html
