Get Educated First
I want to be able to identify who is transmitting. As Iunderstand it I do this by entering the Alpha Tag. The UHP Salt Lake County dispatch alpha tag is Ut Common and the freq is 155.505. With UCAN and the 800 freq's there is no assigned freq.
I know there is a way to do this manually however I am new and have not as yet figured oput how to do it. I can choose a bank and enter 800 freq's but I will not be able to tell who is transmitting. I think the best way is with WIN 97 and the DEC or HEX proghram.
Thanks John
John, I am going to be blunt and to the point, so please don't take offense. Your posts indicate that you are way off track in your understanding of Trunked Radio Systems and how they work. There is no way we can provide you good advice unitl you have a working knowledge of how trunking works.
On VHF, 154.905 is Salt Lake UHP Dispatch (155.505 is Statewide)
On UCAN, the RadioReference alpha tag for Salt Lake UHP Dispatch is
UHP SLCo Disp, the Talk Group ID (TGID) is 19712 in DEC or 4D00 in HEX.
Scanners I am familiar with all use DEC.
If you want to know who is talking, you have to program your scanner with all of the TGID's of all the agencys you want to hear. Along with all those TGID's, you also have to program all of the Alpha Tags for them.
I am not a premium member, so I do not download from RR to my scanner.
I copy the data into MS Excel, Edit the frequencies and TGID's, and copy & paste them into the program for my scanner. If you don't edit them, the numbers will change after you paste them in Win500.
Bottom line is, you need to get educated on trunking or we will not be able to help you. Learn what Talk Groups are, What TGID's are, and you will understand that Alpha Tags are just abbreviated names that are small enough to fit on the scanner display screen. Sample alpha tags:
UU PD1, UHP Car, SUMMIT SO, TOOELE SO, TRANSIT 1, PROVO PD1
