The 164 will work with rebanded systems. You will have to get software to program in the rebanded/multi-table for rebanded motorola systems. You can use Starrcom's Win97 for the PRO-97 that also supports the PRO-163/164 scanners. You will also need the RS 20-047 cable to program the radio.
The cable to the radio that does not have a stereo plug connection to it will not work with the 163/164.
The bottom connector displayed is the connector type. The RS 20-047 is the USB to serial cable to use.
