Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Utility Listening
Utility Listening - Discussions regarding monitoring government, military, aircraft, ship, and other misc communications in the HF/MW/LF bands.
  #21 (permalink)
Old 02-28-2011, 10:57 AM
ridgescan's Avatar
Thanks T-so if I hear the echoing, and the phone-type numbertones that's pretty much relayed..but if I hear Andrews key up and no echoes-no tones-just the linear chatters-and no EAM that's most likely from Maryland or Nebraska depending on the target's location. Good to know. I get Offut here too and Andrews comes through stronger most of the time than them which may be telling too.
BC785D to Diamond D130J @50'
IcomR71A, RS DX-160 to Wellbrook loop @50'
IcomR75,
'54 SX-88 #127 to 100' endfed wire/9:1 trans. @40'
RS Pro 2066 in truck to Larsen Tribander
  #22 (permalink)
Old 02-28-2011, 11:14 AM
pathalogical's Avatar
Originally Posted by CalebATC View Post
Haha, just call and say "Hey, I just heard this on 11175 KHz and wondering what the h*ll it means".
Chinese take-out ! Don't they use numbers to describe all their menu items ? Call 'em up, "...I'll have the number 11 with a side of 175, sweet & sour Alpha November Echo..........standby....." give them something they can't figure out !!! LOL
First Canadian recipient of the Annual Montgomery Burns Award for Outstanding Achievement in the Field of Excellence.
...listening to all the voices in my scanitarium...
  #23 (permalink)
Old 02-28-2011, 7:54 PM
11175 was busy today with lots of calls and ph patches. Here are a few of the notes I logged.
1. Eye Goggle calling Puerto Rico requesting data to be sent. Data sent on 11220kHz.
2. Shadow 91 calling mainsail and then a phone patch is established.
3. Rouge 02 calling any radio. Two calls made.
4. Reach 463 calling MainSail
5. Reach 111 Radio Check
  #24 (permalink)
Old 03-01-2011, 2:20 PM
The echo is caused by multiple transmitters online sending the same messages, not quite in sync. As I understand it Andrews has the ability to select any one transmitter (or any and all) in the system if they so desire, and if they did there would be no echo. If they select more than one TX and you have conditions to more than one then you will possibly hear the echo.
Every time I have heard a transmission using the call "Andrews" but seeming to be from a different transmitter it has been preceded by the control tones. I once heard a transmission that was IDing as Andrews with control tones at the beginning and when Andrews unkeyed Offut audio came up in mid word on the same transmitter (in other words Offut had not been under the Andrews TX and the Offut signal levels and audio faults matched the Andrews levels). My assumption is that Andrews had control of the TX and when they dropped it the Offut ops were, and probably had been, trying to use it.
T!
  #25 (permalink)
Old 03-02-2011, 11:28 AM
ridgescan's Avatar
Yup I have heard Andrews and Offut doubling up with EAMs too-I have also heard Andrews and Offut stepping on an aircraft trying to call them, with an EAM. Hence this thread.
IcomR75,
  #26 (permalink)
Old 03-03-2011, 4:11 PM
CalebATC's Avatar
REAPER calling MAINSAIL
Aircraft wanted ANDREWS to phone patch to REVETMENT on DSN 271-7190. Advised may not need phone patch.
Aircraft just called back saying not needing phone patch, and have a safe trip Andrews it "out!"
Private Pilot | Amateur Radio General K-4-C-N-G
Monitoring from 30 KHz to 1.2 Ghz, Operating 80-70cm
Last edited by ka3jjz; 03-03-2011 at 7:51 PM.. Reason: removed phone number per request
  #27 (permalink)
Old 03-03-2011, 4:22 PM
brandon's Avatar
I believe that DSN # is Offutt AFB RF Orderwire Coordination. It certainly rings a bell.
ScanRiverside.com - solarix.net
  #28 (permalink)
Old 03-03-2011, 4:27 PM
CalebATC's Avatar
Ok, cool. I searched all over for it, couldn't find anything on it.
  #29 (permalink)
Old 03-03-2011, 4:47 PM
CalebATC's Avatar
Hmm.. very wierd.
Just had EAM from Andrews, VERY STRONG!! About 3 minutes after, another. 11175 KHz and 13200 KHz and 15016 KHz ... sounds like airborne platform too. Just said "PAWN? Out"
  #30 (permalink)
Old 03-03-2011, 4:50 PM
CalebATC's Avatar
And another....3 minutes later again. From Andrews, same person who gave last Andrews one.
This isn't normal is it? Kinda creeping me out now..... I'm just waiting to hear SKYKING.
EDIT- And another aircraft calling mainsail for radio check, reporting weak and garbled. At 1056 zulu.
  #31 (permalink)
Old 03-03-2011, 5:24 PM
Strange stuff going on 11175. Today I heard Andrews calling...Horn Fog,Horn Fog message follows....and then a very long EAM message was sent lasting like five minutes.
Anybody know what horn fog is???
  #32 (permalink)
Old 03-03-2011, 5:28 PM
CalebATC's Avatar
Ok, so I guess my PAWN was FOG? Hmm... I guess that could be it.
  #33 (permalink)
Old 03-03-2011, 5:41 PM
ridgescan's Avatar
...and now that I am home from shopping with Rosie-NOTHING
IcomR75,
  #34 (permalink)
Old 03-03-2011, 6:18 PM
CalebATC's Avatar
Just had a "Skyking, Skyking, do not answer 77" on 8992 KHz
  #35 (permalink)
Old 03-03-2011, 7:13 PM
Anyone ballsy enough to dial 312-xxx-xxxx
This topic strikes me as childish but that just my opinion ! _________________
  #36 (permalink)
Old 03-03-2011, 7:19 PM
CalebATC's Avatar
Yeah, I know. Lots of websites say you could goto jail for calling them. I sure wouldn't do it.
  #37 (permalink)
Old 03-03-2011, 7:21 PM
Enough said.
  #38 (permalink)
Old 03-03-2011, 7:30 PM
Ask your buddy if you can use his cell for a quick call ! Then you can keep a eye on his place to see who shows up.
  #39 (permalink)
Old 03-03-2011, 7:36 PM
ridgescan's Avatar
I would take down the #-no offense. It's OK to monitor them and post here-but IMO putting out their # to the world is going too far. Leave them alone to do their work
IcomR75,
  #40 (permalink)
Old 03-03-2011, 7:52 PM
Wiki Admin Emeritus
The phone number has been dropped. In the future - this goes for everyone - don't even pub the area code. Thanks for your cooperation.
best regards..Mike
