Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Utility Listening
Utility Listening - Discussions regarding monitoring government, military, aircraft, ship, and other misc communications in the HF/MW/LF bands.
  #761 (permalink)
Old 10-11-2014, 9:18 PM
Happening right now. A female radio operator is sending EAM traffic with RTTY again. Strange. Time 0120z
  #762 (permalink)
Old 10-12-2014, 9:11 PM
Originally Posted by N1RGR View Post
It seemed to me that it was being transmitted with the voice traffic simultaneously. It did not sound like background noise. I wish I captured a recording.
Guys, here's 2 recordings you may find interesting. One is of the EAM broadcast on 10-10 with what sounds like RTTY synched with the transmission, I originally captured this on 11.175. If you listen to the recording you will notice the signal strength varies. That's because I was clicking through the other GHFS common EAM frequencies to determine if the RTTY was present on all frequencies, Note at the 4.26 minute mark the RTTY signal is not present. The frequency at that moment was 6712. It was the only frequency the RTTY signal was not audible.
The other recording was captured approximately 15 minutes prior to the above. It is (I believe) an E6B transmitting the identical EAM on 6697. A quick note, I have not logged an EAM transmitted on 6697 in over 18 months.
https://soundcloud.com/rickf-2/tracks
Hey, possibly Token will shed some light on this. Any comments appreciated.
RickF
  #763 (permalink)
Old 10-12-2014, 9:14 PM
Track doesn't work
  #764 (permalink)
Old 10-12-2014, 9:23 PM
Just fixed it.
  #765 (permalink)
Old 10-12-2014, 10:20 PM
Originally Posted by Rick1959 View Post
Just fixed it.
I clicked on it and got hip hop music. Try re-sending the link Rick.
  #766 (permalink)
Old 10-12-2014, 10:40 PM
joeuser's Avatar
It may be that we are going to use that music for psychological warfare!
HP-1E,BCD436HP(2),996XT,396XT(3),396T.BCT15X(5).BC250 &296D,780XLT(3).PSR600(2)&800(2).Pro-197(3),164(2),163,2006(2),2001,42,37,21A.TRX-100XLT.DX-440.CenterFire-MultiBand&Discone,ST2,Spider
  #767 (permalink)
Old 10-12-2014, 11:56 PM
hfxChris's Avatar
This may work: https://soundcloud.com/rickf-2
Pro-97 | Pro-137 | Pro-2055 | BCD396XT | BCT15X | BCD996XT | HP-1 | Kenwood R1000 | R820T | Afedri SDR-Net
  #768 (permalink)
Old 10-13-2014, 11:36 AM
Jimru's Avatar
Originally Posted by hfxChris View Post
Cool stuff!
Addicted to all things radio for nearly 50 years, and proud of it!
  #769 (permalink)
Old 10-13-2014, 8:58 PM
Thanks Chris.
  #770 (permalink)
Old 10-17-2014, 11:14 AM
Default Voice & RTTY
I believe the voice over RTTY or vice versa depending on your perspective was an operator error.
Assuming this originated off a Rockwell Collins URG-III system site, there are many ways this inadvertent error could happen. The USAF utilizes a highly customized control system for this radio suite. There is extensive cross patching capability at the control points.
Obviously, radio to telephone (either commercial or DSN), packet, RTTY, various encryptors and so forth as well as good old voice can be patched into the audio path of the system. The sites are connected together via SIPERNET (Secret Internet Protocol Router Network (SIPRNet)). This interconnection mode is employed to connect both individual user sites as well as the station(s) in the network.
It is fairly simple for an operator to make such an error. Potentially audio going to another transmitter, i.e. sitcom could have been “bridged” to the URG-III HF voice path. By the way, there is a “bridge” setup command in the operator console software….
It’s a good catch by our “eagle eared” listeners, however, I would suggest one not read too much into this intercept, and I would consider it an operational error unless we hear more of it.
Happy Listening
  #771 (permalink)
Old 10-18-2014, 2:11 PM
Haley's Avatar
1750z REITERATE doing radio checks with Andrews.
MEATHOOK(?) ground station(?) doing RF checks with MICROFILM, BROADLEAF.
Trying to find suitable frequencies for "customers" coming through??
Any ideas?? They are BUSY today, lots of phone patches. All on 11.175.
IC-R2, Pro51, (2) Pro92B, Pro96, Pro106, Pro18, Pro668, BC125AT, BC246t, BC346xt, BCD396xt, BCD436hp, Kenwood THF6A, Tecsun 380, Tecsun 880, RS DX398, RS DX392, Grundig 550PE
  #772 (permalink)
Old 10-18-2014, 2:13 PM
Haley's Avatar
MEATHOOK, and RIETERATE talking about an orderwire. Around "station" HUMPHREY?
  #773 (permalink)
Old 10-18-2014, 2:17 PM
Haley's Avatar
REITERATE unable to connect to orderwire BRAVO.
  #774 (permalink)
Old 10-18-2014, 2:24 PM
Orderwire Bravo should be 230.900 & 300.400 MHz.
  #775 (permalink)
Old 10-18-2014, 2:33 PM
Haley's Avatar
Thanks MarcelHdt, I had my scanner going with what I thought was a bank of orderwire freq. , but I had that bank off! So thanks again----made me check to see if they were in there anyway. Mike
  #776 (permalink)
Old 10-18-2014, 2:38 PM
On this Dutch site you'll find a list of Orderwire freqs:
North Star Network
  #777 (permalink)
Old 10-18-2014, 3:02 PM
Haley's Avatar
North Star Network
Thank you, a new site for me! Mike
  #778 (permalink)
Old 10-18-2014, 3:14 PM
Haley's Avatar
Can anyone else verify the BROADLEAF call sign? I am not so sure it's not BROADWAY. I cant quite get a good copy. Mike
  #779 (permalink)
Old 10-18-2014, 6:11 PM
Haley's Avatar
PALMLEY (he even spelled it out), phone patch to MEATHOOK wanting to go to analog channel, then passed a EAM. 2210z. Mike
  #780 (permalink)
Old 10-20-2014, 6:21 AM
Hi Mike,
BROADLEAF was correct, however, PALMLEY was in fact PALM LEAF.
