Token
Since the return of South Korean numbers station V24 in February (noted here http://forums.radioreference.com/ut...s-station-v24-active-again-feb-15-2016-a.html ) I have been loosely following the station to get a feel for its habits and schedule.
Based on observations since V24 re-started transmissions on February 14 I have put together a prediction chart. For the first couple of months V24 appeared to be trying new things and has only settled into relatively stable operation for the last 6 weeks or so.
V24 appears to have narrowed its times of operation from past operations, repeated transmissions appear to only happen with start times from 1430z to 1600z. *There have been some transmissions before 1430z, however those appear to have been before V24 started using a repeating schedule.
V24 has changed the cycle that it operates on. *In the past it operated two days in a row with the same message at the same time on the same frequency. *So on day 5 of the month at 1500z on 5715 kHz a transmission would occur, and the next day, the 6th day of the month, the same message would be sent at the same time on the same frequency. *However now it no longer does this. *Instead now it waits a day between transmissions. *So that on the 5th day of the month at 1500z on 6215 kHz a transmission occurs, it skips the 6th day, and on the 7th day of the month at 1500z on 6215 kHz the same transmission is sent again.
My newest prediction chart can be found at the same place it is always at:
http://www.tokenradio.net/Radio/SharedFiles/NumbersTfer/V24_M94_latest_sched.JPG
T!
T!
