USCG HF log
Caught the US Coast Guard on 8993USB last night talking to a fishing vessel. First time I've heard that before. Its not exactly a distress frequency from what I know, not sure what was going on with that. Only caught the part end of the conversation and then nothing but silence. I know the USCG base here in Kodiak was transmitting, never heard where the boat was.
ridgescan
San Francisco, Ca.
Should be 8983kHz. That is Coast Guard freq as well as 5696. If you park on one of those you will hear stuff.
ah, my mistake, yes it was 8983. I was cruising in USB and didn't switch to AM. I'll keep an ear on both. Thanks.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Alaska, these logs should go to our Utility Listening forum. I will move them tonight.
Thanks for the logs...Mike
juneau
Juneau AK
Hi Alaska
You will hear occasional use on 8983 as a secondary frequency to 5696. 5696 is busy all day from COMMSTA Kodiak. You can also copy Alaska CG traffic on the Cothen ALE network
Milcom Monitoring Post: COTHEN Net - Update 21 March 2018
as well as the Kodiak ALE net listed on the above page.
Locally you can hear some traffic on 345.000 Mhz coordinating aviation operations between aircraft.
Matt
