Vertext FTL-2011..narrow band capable?
aschenavar
Found a decent deal on a used one and I cant seem to find anywhere online where it says clearly yes or no if it is narrow band capable. I see in some descriptions that 12.5khz is "optional" ..is this something I can choose in the programming aspect of it?
mm
oregon
You can select 12.5 KHz tuning steps if you wanted to tune in the Federal Govt. band, 162 to 174 MHz range, but the radio still uses a 25 KHz I.F. so no the radio is not narrowband capable.
RodStrong
West
The 2011 and 7011 series will only be good for ham after the end of this year. Outstanding radios. Been using them from 1994 nearly non stop to today.
aschenavar
ahhhh...well then, in that case I'll just keep shopping around I guess..thanks fellas
