Vertex vx-829 mod for ham bands
n2meg
bronx new york
Anyone know how to get CE-59 Ver 4.04 into dealer mode or is there is mod to get this radio into the ham bands. 450 mhz - 520 mhz is the spread on my radio. I want to get 450 mhz down to 440 mhz.
Sorry if this was asked before, I did not find anything on this here... I also have a vx-4207 on 403mhz-470mhz and I would like to get that to RX on the UHF T band to listen to local PD...
thanks in advsance for any help...
Pablo n2meg...
n2meg
bronx new york
Pablo n2meg...
ok 99 views and no response that's nice! I guess someone is going to ask how I did it. I got the vx-829 modded.
Now for the vx-4207
KG6GTH
Santa Clarita Valley
You need a Hex Editor... And the edit the Default File... I have a VX-P829 and did the same... I have at home and will try to post how to later...
62Truck
Ordinary Subscriber
Uranus
I know I've never had any luck taking any of the Vertex stuff out of band besides the VXD720 and the 7200.
I had a VX420 I was trying to get down into the hamband but all the info I cam across wouldn't work.
n2meg
bronx new york
Yes I did the vx-829 it works great, I hex edit the file.
Now the vx-4207 I also Hexed and I got it out of band but that did not work. I have also noticed with the new versions of the programs you can't put the programs in dealer mode. Has anyone got the CE-59 to go into that mode so you can just change the greyed out frequency spread?
n2meg
bronx new york
O.k. After Hexing and getting the software into dealer mode, the mod works but the vx-4207 radio will not RX or TX out of band. So much for that. Thanks all for the help!
62Truck
Ordinary Subscriber
Uranus
how far out of band did you try to go out of curiosity.
n2meg
bronx new york
I did up to 480.000 that didn't work, did 512.000, 520.000 what happends the software goes there but
the radio on the upper modded freq will start blinking on the screen. 476.XXXX will blink on the radio
nothing can be heard but will TX, I did not check for power output. This is on the VX-4207 403-470 MHZ version.
62Truck
Ordinary Subscriber
Uranus
Sounds like the VCO isn't locking. You might be able to get to lock. What you will need is a volt meter and a service monitor.
ASTRORADIOS168
Brooklyn, NY
you have the file ?? would like it can u do 470 + on A version UHF ??
