Prymeblu for Vx-824
tbrown01
Temple Hill Kentucky
I bought one of these and I followed the instructions that came with it and it won't work, I called the company and they said I needed to switch on the power accessory setting in the programming, I have never seen this setting, can someone help me or does prymeblu not know what they are talking about
SCPD
QRT
Virginia
Sort of old but did you get it figured out? Some ear devices should be turned on then long press and hold the pryme adapter ptt where light is. Once it flashes wait and see if your device pairs. It if don't press and hold your bluetooth device earpiece talk button see if it pairs. These adapters will work however are designed as all for the actual mission critical kits but can be paired with compatible devices. Allot of times it boils down to your bluetooth device process of pairing by either long pressing the bluetooth ear piece till it flashes or the proper setup process for the bluetooth ear piece. All these adapters are the same regardless of btand. It is possible your bluetooth earpiece is not compatible. Pryme and the actual vendors of the radio are only ones I'd use. Mission critical for sure get the mission critical kits. But regular ear pieces are good for monitoring, ham, ps in admin or non life threatening points. Handy for meetings for those who prefer just a radio on belt no shoulder mic wanting to hear traffic while in a press or body meeting.
SCPD
QRT
Virginia
I had a few pryme blues for icom and xts. They were spares aside from oem versions. I recall the pryme would work but sometimes a device wouldn't pair. Troubleshooted half time non compatible earpiece to the earpiece itself pairing method. The xts ones seemed to seek out the earpieces that were in search for pairing mode. Hmmm wonder if it was a defective unit you had got. But good you got your money back.
